Novation Circuit Rhythm Sampling Groovebox Now Available To Pre-Order
Novation today officially introduced the Circuit Rhythm, the third groovebox in the Circuit family.
The Circuit Rhythm keeps the streamlined grid-based sequencing interface of the original Circuit, but focuses on sampling and sample sequencing. Instead of offering two synthesis and 4 drum tracks, the Circuit Rhythm features 8 Flexible Sample Tracks.
With the Circuit Rhythm, you can record samples directly to the hardware, then slice, sculpt and resample your sounds. You can record performances quantized or off-grid, and arrange them with eight sample tracks. You can also add effects, including lo-fi tape, beat repeat and more.
Features:
Record samples directly to the hardware, then slice, sculpt and resample your sounds. Slice, reverse, loop, play chromatically, and more
Perform with grid FX
Make beats with eight sample tracks, each with their own 32-step patterns, chainable for up to 256 steps per track.
Capture your groove quantized or off grid into the sequencer, and keep your beats evolving with probability and pattern mutate.
Effects ¨C add reverb and delay, make your mix pump with sidechain, and add punch with the master compressor.
Comprehensive connectivity ¨C Connect to your studio with full-size five-pin MIDI in, out, and thru, and analog sync out. Sample to mono, or monitor through stereo out or with headphones.
microSD card slot too save and access thousands of samples and projects.
The built-in rechargeable battery provides up to four hours of battery life
Specifications:
32 RGB backlit velocity-sensitive pads
28 RGB backlit tactile click buttons
Power button with charge status LED
USB-C socket
Kensington MiniSaver slot
MicroSD card slot
3x MIDI DIN (In, Out, Thru)
3.5mm sync out
L/R Sample In Pair
L/R Audio Out Pair
Headphones out
8x endless encoders with RGB indicators
Master volume pot
Master filter pot with centre detent
»®Öصã:
Novation Circuit Rhythm Sampling Groovebox Now Available To Pre-OrderNovation today officially introduced the Circuit Rhythm, the third groovebox in the Circuit family.The Circuit Rhythm keeps the str ...
