New iOS MIDI Sequencer App
SnakeBud AUv3 plug-in is inspired by the Eurorack sequencer module Make Noise Rene
SnakeBud is a new AUv3 MIDI Sequencer app said to be inspired by the eurorack sequencer module Make Noise Rene. Here's the full details direct from developer Cem Olcay...
SnakeBud is a 16-step AUv3 MIDI Sequencer with a 4x4 grid. You can set the note, gate, velocity and probability values for each step and you can also toggle them on/off.
It has 56 snake patterns for the sequencing on a 2-dimensional grid which differentiates it from the one directional sequencers. You can get 56 different sequences within the same grid.
SnakeBud has a music theory engine with 40+ scales which can be changed from the settings menu. You can lock the notes in a scale and you can change the scale even when the sequencer is running.
With the randomiser, you can randomise the notes, the snake pattern or all parameters at once.
You can save the current state in a pattern and create as many patterns as you want by pressing the plus button in the patterns section on the bottom-left side of the screen.
The AUv3 plugin exposes more than 90 Audio Unit parameters. You can control them or even automate them with the supported audio unit host apps such as AUM, Cubase, apeMatrix.
The standalone version of SnakeBud supports Ableton Link.
SnakeBud does not produce sound itself, it's a MIDI app and requires an audio app in order to work. Just route the SnakeBud MIDI output to the audio app's MIDI input and arm the sequencer.
Features:
16 step sequencer on a 4x4 grid
56 snake sequence patterns
unlimited number of patterns
90+ AU parameters
40+ scales
Note/Velocity/Gate/Probability/Toggle for each step
Randomiser
»®Öصã:
New iOS MIDI Sequencer AppSnakeBud AUv3 plug-in is inspired by the Eurorack sequencer module Make Noise ReneNew iOS MIDI Sequencer AppSnakeBud is a new AUv3 MIDI Sequencer app said to be inspired by t ...
