The Magic Power Cable takes the 5V output of a USB socket and steps it up to power any 9V DC powered synthesizer or guitar pedal (with adapter).
Magic cables
This is not a new concept and it¡¯s less about magic and more about electronics. MyVolts has been doing something similar for a while with their more professional looking ¡°Ripcord¡± cables. The Magic Power Cable is a less glamourous and cheaper version that¡¯s been picked up by Error Instruments.
However, what Error Instruments has done is come up with one that fits and powers little desktop synths and noise boxes in particular. They also have an adapter cable to change the polarity of the barrel end to run guitar pedals.
So, why would you want to run synths and pedals from a USB socket? Because this means you can use any cheap USB power pack to run your gear outside, on the move or anywhere where you wouldn¡¯t be able to plug in. Saves a ton on regular batteries.
YouTube
By loading the video, you agree to YouTube¡¯s privacy policy.
Learn more
Load video
 Always unblock YouTube
It¡¯s a useful piece of kit. Do check that the thing you want to power is 9V before you buy.
The Magic Power cable for synths is
»®Öصã:
The Magic Power Cable takes the 5V output of a USB socket and steps it up to power any 9V DC powered synthesizer or guitar pedal (with adapter).Magic cablesThis is not a new concept and it¡¯s less abo ...
