Óü¤¹â´«ÊäÁ¢ÌåÉùÒôƵÐźÅ
±¾ÎÄΪÃÀ¹ú°¢¿ÏÉ«´óѧ·ÑÒ®ÌØÎ¬¶û·ÖУ£¨×÷ÕߣºWilliam Austin Curbow£©µÄѧʿÂÛÎÄ£¬¹²34Ò³¡£
Ìá³öÁËÒ»ÖÖÀûÓü¤¹â¼¼Êõ´«ÊäÒôƵÐźŵÄÌæ´ú·½·¨¡£±¾ÎÄÖ÷ÒªÑо¿ÒôƵ·Å´óÆ÷×ÓϵͳµÄÉè¼Æ¡¢·ÂÕæºÍÐÔÄܽá¹û¡£ÀûÓÃPSPICE¼ÆËã»ú·ÂÕæÈí¼þ¶ÔÒôƵ·Å´óÆ÷×ÓϵͳµÄÀíÂÛÉè¼Æ½øÐÐÁËÑо¿¡£ÔÚÔëÉùÊäÈë¼¶¡¢¸ßµçѹÔöÒæµ¥ÔªºÍµÍ×迹Çý¶¯Æ÷Èý¸öÁ¬½Óµã¶ÔÒôƵ·Å´óÆ÷½øÐÐÁ˲âÊÔ¡£Í¨¹ýÀíÂÛ¼ÆËã¡¢PSPICE¼ÆËã»úÈí¼þ·ÂÕæ¡¢Ê¾²¨Æ÷²âÊÔ³ÉÆ·µÈÉè¼Æ¹ý³Ì£¬¶ÔÒôƵ·Å´óÆ÷½øÐÐÁËÉîÈëÑо¿ºÍÑéÖ¤£¬ÒÔ´ïµ½Ô¤ÆÚµÄ¹¦ÄÜ¡£´ËÍ⣬»¹¶ÔÂö³å¿í¶Èµ÷ÖÆ¼¼Êõ½øÐÐÁËÑо¿ºÍʵÏÖ£¬²¢Óþ«ÃÜ555¶¨Ê±Æ÷ʵÏÖÁËͨ¹ý¼¤¹â´«ÊäÒôƵÐźš£
An alternative method for transmittingaudio signals via the use of laser technology was presented here. The primaryfocus of this document is on the audio amplifier subsystem including thedesign, simulation, and performance results. Simulations using the PSPICEcomputer simulation software were utilized to investigate the theoreticaldesigns of the audio amplifier subsystem. The audio amplifier was examined inthree junctures including the noisecanceling input stage, the high voltage gaincell, and the low impedance driver. Through the design procedure usingtheoretical calculations, simulations using PSPICE computer software, and examinationof the finished product with an oscilloscope, the audio amplifier was greatlyinvestigated and verified for desired functionality. In addition, thepulse-width modulation technique was examined and implemented with precision555 timers in order to transmit audio signals via laser.
1.ÕªÒª
2. ÒýÑÔ
3. ÀíÂÛ±³¾°
4. Éè¼Æ¹ý³Ì
5. ²âÊÔÓë½á¹û
6. ½áÂÛ
»®Öصã:
Óü¤¹â´«ÊäÁ¢ÌåÉùÒôƵÐźű¾ÎÄΪÃÀ¹ú°¢¿ÏÉ«´óѧ·ÑÒ®ÌØÎ¬¶û·ÖУ£¨×÷ÕߣºWilliam Austin Curbow£©µÄѧʿÂÛÎÄ£¬¹²34Ò³¡£Ìá³öÁËÒ»ÖÖÀûÓü¤¹â¼¼Êõ´«ÊäÒôƵÐźŵÄÌæ´ú·½·¨¡£±¾ÎÄÖ÷ÒªÑо¿ÒôƵ·Å´óÆ÷×ÓϵͳµÄÉè¼Æ¡¢·ÂÕæºÍÐÔ ...
