Fanan team releases Yogi - Rhythmic Pad Machine for Windows
Fanan Team
Fanan team has released a rhythmic pad machine for Windows called Yogi.
They say:
Yogi is another member of our cosmic pack and is basically 3 oscillators synth with a built in arpeggiator that modeled by using 2 different synthesis methods: subtractive and physical modeling. It armed with 3 totally independent pad oscillators that creates wide range of atmospheric sounds. It also armed with 6 built-in effects with separate oscillator connectivity and mixing, 3 modulation LFOs (1 per osc) 3 modulation envelops (1 per osc), modulation matrix, 10 filter types, ring modulator, spread modulator, noise generator, random phase generator, full mono mode functionality (per osc), new modeled chords arpeggiator with built-in 999 arpeggios seeded, a dominator for internal ducking hierarchy and indeed, the special character feature.
Main features:
3 pad oscillators with 8 pad waveforms for each.
Special sound character feature (picky, crisp, glass, metal).
Independent filter module with 8 unique filters.
Dedicated modulation LFO and envelop per oscillator.
Independent portamento per oscillator.
Velocity limiter and fixed velocity modes.
6 built-in effects with independent send per oscillator.
Quick hi-pass-lo-pass filter per oscillator.
Spread effect per oscillator.
Chords driven arpeggiator with 999 built-in arpeggios.
resizable GUI.
Full MIDI map manager.
Price: $17 as a member of the "Cosmic Pack" bundle.
»®Öصã:
Fanan team releases Yogi - Rhythmic Pad Machine for WindowsFanan TeamFanan team has released a rhythmic pad machine for Windows called Yogi.They say:Yogi is another member of our cosmic pack and is ba ...
