Fastlane and Soundmanufacture teamed up to design a Max for Live Device (M4L) which enables a Push owner to customize their hardware inside Ableton Live. They say:
Push Hacker 2 is built from ground up and brings a better performance and new & sofisticated features.
With Push Hacker 2 you are able to expand the features of Push 1 or Push 2 to your personal needs.
It enables you to manually re-assign any of Push's features (buttons/rotaries/pitch bend/matrix pads) to any parameters in Live (audio effects/MIDI effects/Clips/ Clips slots/Mixer/Solo buttons etc....)
whilst in 'Note Mode' or 'Session Mode'
Features:
Map buttons & dials to any parameters.
Move the clip grid.
Select individual tracks.
Solo Tracks.
Recording & playing clips.
Draw curves for dlider parameters.
Price: 12 Euro / $16.
»®Öصã:
Fastlane and Soundmanufacture teamed up to design a Max for Live Device (M4L) which enables a Push owner to customize their hardware inside Ableton Live. They say:Push Hacker 2 is built from ground up ...
