Online retailer Thomann has just added a new bit of audio gear for its inhouse t.bone range. A clip-on wireless mic system, Sync is a simple and affordable way of improving the audio quality of your videos and vlogs.
t.bone Sync
Vloggers and video creators rejoice: There¡¯s a new wireless mic system in town that¡¯s easy to use and super affordable. If you¡¯ve tried wireless systems before but found them either too messy or too expensive, then the Sync could be for you. And if you¡¯re looking to grab your first wireless mic set to make your video production workflow a bit more professional, Sync should be on your radar.
Sync is a wireless, clip-on mic system based around rechargeable transmitters and receivers. You can clip the transmitters and receivers onto your clothing or your belt. Furthermore, they¡¯re also suitable for hot-shoe camera mounting too, adding to the versatility.
Each transmitter pack incorporates an integrated microphone; simply switch on, clip-on and go! Undoubtedly, you¡¯ll also be happy to hear that conventional lavalier microphones are also included. It should be noted that each transmitter has a 3.5mm external mic input and a switchable high-pass filter.
Hassle-Free Tech
The Sync system uses the 2.5 GHz digital band and for this reason offer you hassle-free, license-free, one-button pairing. Additionally, the connection range is 50m line of sight; clearly enough for most vloggers and video interview situations. t.bone Sync is available in two different versions offering different configurations of transmitter and receiver.
t.bone Sync 1 offers one transmitter and one receiver. t.bone Sync 2 gives you an additional transmitter, ideal for multi-host vlogging and presentations. Both Sync 1 and Sync 2 come bundled with a comprehensive accessories pack:
3.5mm TRS to TRS camera spiral cable
3.5mm TRS to TRRS smartphone cable
Plug-in lavalier mic(s) with windscreen(s)
USB charging cable
Hardshell carry case
Alternatives? Admittedly with this form factor, you¡¯ll find little else to compare. There¡¯s really only the Rode Wireless Go II system that offers a similar set of features, but at a significantly higher cost. The Wireless Go II does have a longer range of 200 m line of sight compared to 50 for the Sync. While 200 m range is impressive, in a real world scenario used to camera, I think 50 m is plenty adequate. Altogether then, the t.bone Sync looks like something of a bargain.
»®Öصã:
Online retailer Thomann has just added a new bit of audio gear for its inhouse t.bone range. A clip-on wireless mic system, Sync is a simple and affordable way of improving the audio quality of your v ...
