SampleScience 909 Lab Makes It Easy To Tune Your Drums To Your Track
SampleScience has introduced 909 Lab, a new virtual instrument designed for playing 909 sounds chromatically, so it¡¯s easy to tune them to the rest of your track.
Features:
All the 11 original sounds of the 909
Tonal drum sounds key mapped to piano roll
Tonal shaper
Amp floor and ceiling controls
Saturation
Reverb (for some of the sounds)
Note: It is currently available for Windows 8.1/10 and macOS El Capitan to Mojave (not compatible with Catalina)
Pricing and Availability
909 Lab is available now for $30 USD.
»®Öصã:
SampleScience 909 Lab Makes It Easy To Tune Your Drums To Your TrackSampleScience has introduced 909 Lab, a new virtual instrument designed for playing 909 sounds chromatically, so it¡¯s easy to tune ...
