An Overdrive Sent from the Gods
Zeus Drive has arrived direct from the heavens. With its highly sought-after overdrive boost circuit, this golden chalice among overdrive pedals has a luxurious warm tone and quite an astonishing dynamic response, injecting the Nectar of the Gods directly into your guitar sound.
Clean or Distorted? Or Better Still Both!
Zeus Drive¡¯s dual concentric gain control progressively blends overdrive into your clean signal whilst simultaneously increasing clipping for a crystal clear, amp-like touch and response.
Godly Tone Control
Rather than being armed with the same old traditional tone control, Zeus Drive¡¯s treble knob allows you to dial in and tailor your highs without ever thinning the lows.
FAT Mods
Engage the FAT switch on Zeus Drive to increase bass and literally fatten up that bottom end for gut-wrenching, chugging, riffery.
Devine Design in Sound
Zeus Drive internally steps up your 9V DC voltage resulting in huge dynamic range and buckets of output level on tap via the volume control, beyond all proportion to its compact size.
Germanium Powered Analog Circuitry
The drive section of Zeus Drive¡¯s all-analog circuit, comes fully armed with a pair of 1N34A Germanium diodes that deliver smooth, soft clipping and sweet, pleasing highs.
Hidden Treasures
We¡¯ve included a DIP switch inside the belly of Zeus Drive for you to choose between true bypass or a high-quality discreet buffered bypass. The option is all yours.
Tough and Compact
Zeus Drive is housed in an amazingly compact, built-like-a-tank metal box. Ever conscious that your pedal collection may be growing while your pedalboard may not, we¡¯ve mounted the jack sockets and power input on the top of the housing to save you valuable pedalboard real estate. Allowing you to stack more pedals than ever before in a row.
Designed in TC Electronic¡¯s Headquarters in Denmark
For more information, visit: https://www.tcelectronic.com/tcelect...odelCode=P0EBW
»®Öصã:
An Overdrive Sent from the GodsZeus Drive has arrived direct from the heavens. With its highly sought-after overdrive boost circuit, this golden chalice among overdrive pedals has a luxurious warm ton ...
