Tone2 Audio has announced the forthcoming release of Nemesis 2, a synthesizer plugin for Windows and Mac OS.
The update to v2.0 is a major update, which is available for free. It includes a big GUI, many new features, new waveforms, higher sound-quality, better performance and many enhancements.
Nemesis 2 is downward-compatible with all previous versions. All existing song projects and patches can be loaded without any further steps necessary.
What's new in v2.0?
New features:
A big interface is available beside of the normal scale now.
It is possible to select from 4 GUI sizes in 'CFG'.
The synth can create an unlimited number of new sounds with FILE->'Create random patch'.
119 additional Waveforms including many noisy and complex types.
New effect 'Hypersaw' which stacks 3,5,7 or 9 voices.
New effect 'Haas Effect' which creates the impression of positioning a sound source.
New effect 'Chorus Standard' which has the sound of an industry-standard chorus.
The texts shown in the patch-browser on Mac support hi-dpi drawing.
The plugin detects the best GUI-size automatically.
Added Digital-Signatures for the installers on PC.
Added Notarisation for the installers on Mac.
Support for Code-Signing on the Mac, since new hosts may require it to be able to run plugins.
Compatibility with MacOS Catalina and Big Sur.
Completely new AudioUnit interface.
Keyfile-dialogue is available in German.
Enhancements:
The interface has a smoother rendering with more contrast.
Much faster loading of plugin and patches.
Compatibility with Windows 10.
Enhanced sound of MultiTap, Delay, PingPong, DelayDual, Doubler DelayBand. They sound less detuned.
More beautiful fonts.
Patch-browser has more contrast.
Reworked many graphics.
Many small enhancements.
New features and enhancements (standalone-version for PC):
Added a recorder that can export your jam-session to a wav-file.
The BPM-rate can be changed.
Added a soft-clipping-algorithm with low harmonic distortion.
The current patch can be saved on exit and is reloaded automatically on start.
MME-driver support.
Midi-through support with output-routing.
Added MIDI-velocity-curves with multipoint-splines.
Optional MIDI-transposition with up to +-48 semitones.
Optional MIDI-channel-filtering.
The current BPM-rate, CPU-load and volume is shown on the top-panel.
Tooltips are shown on the top-panel.
Lower latency for the sound-card drivers.
More responsive GUI with 120 Hz refresh-rate for smooth knob movements.
Faster closing of plugin.
Changes:
32-bit on PC is not longer supported. If you still use a 32-bit host, install Nemesis 1.6 instead.
MacOS 10.7 is the minimum requirement now. If you still use 10.6 or 10.5, install Nemesis 1.6 instead.
Fixes:
Fixed a rarely appearing crash that could happen when the plugin was closed while a tooltip was shown.
Fixed an unlikely crash on the Mac which happened if the plugin was closed immediately after opening the browser.
System requirements:
PC: Windows XP / 7 / 8 / 10 / Vista (32-bit or 64-bit).
PC formats: 32-bit VSTi, 64-bit VSTi, standalone.
Mac: MacOS 10.7 or higher / MacOS 11; Intel CPU or Apple M1.
Mac formats: 32-bit VSTi, 64-bit VSTi, 32-bit Audio Unit (AU), 64-bit Audio Unit (AU).
Price: TBA.
Nemesis 2 features user-friendly copy-protection: No cloud, no dongle, no need to be online.
»®Öصã:
Tone2 Audio has announced the forthcoming release of Nemesis 2, a synthesizer plugin for Windows and Mac OS.The update to v2.0 is a major update, which is available for free. It includes a big GUI, ma ...
