Velvet Machine Sonic Texture Generator Now Available For Mac & Windows
Developer Yuri Turov of Phonolyth has released Velvet Machine for macOS (AU+VST3) and Windows (VST3), previously available only on iOS.
Velvet Machine is described as ¡°a sonic texture generator / blur / non-linear reverb effect¡±, based on real-time convolution with enveloped velvet noise.
It¡¯s designed to:
Stretch and blur out even short sounds to lengths of up to 10 seconds.
Produce reverb-like textures with flexible volume envelope (including reverse, fading in and out, pulsating etc.).
Work as a variable density random multi-tap delay (bordering on granular-like sounds).
Features:
Flexible volume envelope with arbitrary number of segments and curvature.
Effect time ranging from 50 ms to 10 s.
Response density adjustable from 1 to 2000 repeats per second.
Predelay up to 1 s.
Host tempo sync for time and predelay.
High cut and low cut filters for the effected signal.
Mix adjustable from 100% dry to 100% wet.
Mix Lock to switch presets while keeping the dry/wet mix constant.
Fully resizable vector-based UI.
Cross-platform preset format.
The Mac version is also a Universal Binary 2, meaning it runs natively on both Intel and Apple Silicon.
Pricing and Availability
Velvet Machine is available now with an intro price of $16 until June 1st 2021 (Reg. $32). A free demo version available. The iOS version is also on sale: $3.99 (Reg. $7.99).
»®Öصã:
Velvet Machine Sonic Texture Generator Now Available For Mac WindowsDeveloper Yuri Turov of Phonolyth has released Velvet Machine for macOS (AU+VST3) and Windows (VST3), previously available only on ...
