Choris free vocal sample library for Kontakt by Rossignol-Studio
Rossignol-Studio has announced the release of a new choral sample library for Native Instruments Kontakt. Featuring recordings from Frederick Begnon¡¯s voice, Choris is designed to make ethereal pads.
Sound Voice nature more synthetic sounds, you have access to an infinite range of possibilities.
Choris was sampled on three levels, low, medium and high, it is composed of two octaves: G1 C2 normal voice and C # 2 to C3 falsetto. The samples are .WAV 24-bit 41.1 kHz. 84,3 Mo (ZIP 67 Mo).
The interface consists of four ADSR controls with a bypass button and five buttons effects: reverb, delay, chorus, flanger and phaser. Some presets are available to start playing with Choris.
The library is free to download for the full version of Kontakt.
If you haven¡¯t yet, make sure to check Rossignol-Studio¡¯s other Kontakt instruments as well. All commercial libraries were set free last year.
More information: Rossignol-Studio
»®Öصã:
Choris free vocal sample library for Kontakt by Rossignol-StudioRossignol-Studio has announced the release of a new choral sample library for Native Instruments Kontakt. Featuring recordings from Fred ...
