iD14 delivers the audio performance of a large format console in a compact and elegant desktop package. iD14 provides a pair of world-class Audient console mic pres, class-leading Burr Brown converter technology, console style monitor control, JFET D.I and the revolutionary ScrollControl. With its versatile feature set and intuitive layout, iD14 will become the hub of your studio in no time.
We are the only company that use the same Class-A mic pre design throughout our entire product range, whether you¡¯re in the studio with an Audient console or on the road with iD14, you¡¯re always guaranteed the same world class Audient sound.
Developed by design legend David Dearden and optimised over 18 years of refinement, our mic pre is used by thousands of professional studios around the world. With its versatile nature and smooth tone, the iD14 will quickly become your ¡®go to¡¯ mic pre.
iD14 provides you with high performance AD-DA converters from Burr Brown, the leaders in converter technology. Quality in the analogue stages of design comes from years of experience as analogue console designers, and when coupled with outstanding converter technology it enables you to hear audio as it¡¯s supposed to sound. The importance of converters should never be underestimated. Experience audio the Audient way.
As well as offering you 2 channels of mic pre, iD14 has a harmonically rich JFET D.I input. Designed to replicate the input stage of a classic valve amplifier, you can plug your guitar, bass, keyboard or drum machine straight in and start recording instantly.
We understand the need to keep things simple and iD14¡¯s mixer app was designed with that in mind. Whether you¡¯re creating low latency cue mixes or utilising the flexible monitor control, iD14 tightly integrates the hardware and software making the recording process easy. Enabling you to concentrate on what¡¯s really important - the music.
Audient iD14 Features
2 x Class-A Audient Console Mic Preamplifiers
High Performance Burr Brown AD/DA Converters
1 x Discrete JFET Instrument Input
Main Speaker Output
Independent Class-AB Headphone Output
Full Monitor Control Functionality (software controlled)
ADAT Input for Expandability
Low Latency DSP Mixer
iD ScrollControl Mode
All-Metal Enclosure
USB2.0 Bus Powered
»®Öصã:
iD14 delivers the audio performance of a large format console in a compact and elegant desktop package. iD14 provides a pair of world-class Audient console mic pres, class-leading Burr Brown converter ...
