Transformer Effect Plugin Plugin by Rast Sound
Transformer is a self modulating quad resonator bank where you can set mode of resonators (how they sound), tunings, decay times and levels as you want and even modulate them without going into complex automations through your DAW. Add slight tonal excitement, colouring or shape your input sound into something completely new with Transformer effect plugin.
{See video at top of page}
3 TIMBRAL MODES & BASE NOTE ADJUSTMENT
Transformer comes with 3 timbral modes, you can think of it as different sound characters like string or wind. These modes are powered by mathematical models to create unique and natural final sound. After finding the mode you like, adjusting your base tone to fit your song.
4 RESONATORS & EFFECTS
A resonator emulates the acoustic resonations of an instrument. Now think of driving four of them with any input you like ranging from percussive/beats to types of noise, from plucks or higher tonals and bass. Results will be tonally focused resonations still partly having the spectral imprint of the input where you can further shape decay, tone, spread and predelay.
RICH LFO BANK
Modulate the levels, the decay times and pitches for a rich signature output with a detailed LFO module. Smart module lets you connect to all resonators together as well as separately.
»®Öصã:
Loopcloud 6 Introduces AI Search TechnologyLoopcloud gives musicians studio-quality samples, loops and instruments to take their music further. It¡¯s the all-in-one production partner that provides in ...
