Baby Audio releases Smooth Operator
The opposite of a LoFi plugin.
It¡¯s hard to explain spectral processing in a few sentences, but chances are you¡¯re familiar with LoFi plugins. Smooth Operator is basically their opposite. It combines equalization, spectral compression and resonance suppression into a singular creative experience that¡¯s instant and intuitive. Use it to perfect your tonal balance and add a touch of clarity.
Our spectral detection algorithm adapts to your audio 44,100 times per second and automatically eliminates fatigued frequencies. This gives you full control to shape your signal and bring out more definition.
HIGHLIGHTS
Brings out clarity and smoothness across instruments, vocals and mix busses.
Allows for creative tone shaping without artifacts or harsh resonances.
Intelligent algorithm that automatically detects and resolves fatigued frequencies.
An alternative to EQ, compression and resonance suppression in one unified workflow.
Intro sale - save 44% (Reg: $69)
For more information: https://babyaud.io/smooth-operator-plugin
»®Öصã:
Baby Audio releases Smooth OperatorBaby Audio releases Smooth Operator-screen-shot-2021-04-26-20.15.09.pngThe opposite of a LoFi plugin.It¡¯s hard to explain spectral processing in a few sentences, bu ...
