HoRNet MultiFreqs: spectrum analyzer plug-in for up to 28 tracks at once
Virtually any type of metering under the sun can be added to your DAW these days, so it takes a bit extra to stand out in the field. MultiFreqs by HoRNet plug-ins is born out of the developer¡¯s traditional focus on usability and problem-solving. Instead of enough metering options to service a fighter jet, the plug-in offers two types of spectrum analyzers and puts up to 28 audio tracks on the graph at once. This way, hunting down frequency clashes between sounds and instruments becomes a breeze.
HoRNet MultiFreqs
The first visualizer is called ¡°analog¡± and it takes on an analog hardware spectrum analyzer. The specific unit isn¡¯t mentioned, but it¡¯s an old studio piece which remains in action today. The second visualizer is called ¡°digital¡± and it¡¯s a typical FFT-based digital spectrum analyzer you¡¯d find in digital audio.
Both types of visualization let you switch between peaks, average, and conflict metering modes. You can also change the range (in dB), integration times, and Mid/Side mode (stereo sum or difference). All that¡¯s left to do is choose the audio tracks you want to visualize and toggle them on or off as needed. The plug-in reads the track names but you can change the labels inside it. You can also choose the color of each track and save/load presets.
Like most HoRNet plug-ins, MultiFreqs is a straightforward and reliable tool. This kind of uncomplicated multi-track metering really helps me balance things out in a session.
Price and availability
MultiFreqs is sold from the HoRNet website, priced EUR 15. A demo is not provided but an instant full refund is offered within 15 days when you purchase the plug-in but don¡¯t like it. MultiFreqs runs under macOS 10.11 or later and Windows 7 or later in 64-bit AU, VST, VST3 and AAX formats. Note that only the VST3 and AAX formats can read the names of audio tracks.
»®Öصã:
HoRNet MultiFreqs: spectrum analyzer plug-in for up to 28 tracks at onceVirtually any type of metering under the sun can be added to your DAW these days, so it takes a bit extra to stand out in the fi ...
