Fanan team releases Gala - Multi Instrument Ensemble
Fanan Team
Fanan team has released Gala, a multi instrument ensemble plugin.
Gala replaces 7 instrument synths (Alkamanat, stringya, brassinematic, clarinetica, folkordion, orientis and saxophia).
Fanan team says:
Gala is based on a physical modeling code of a virtual analog oscillators that work in an open mixer format and mixes up 4 independent top crafted wave-forms with a high dynamic range and generates 28 instruments ensemble emulation, each with it's own size and color which can mix any 4 instruments together and create rich multi combinations, articulations and textures.
Gala comes in 2 versions:
Gala XL - 28 instruments (royal pack member).
Gala free - 15 instruments (Free).
Both versions share the same basic features (listed below) while the differences between them are:
Gala XL has keyboard split feature which allows splitting the hardware keyboard into 2 zones and routing each of the 4 oscillators to any zone.
Gala XL has a new feature called "note slider" which allows creating note sliding sequence effect.
Gala XL instruments:
3 pop strings.
5 oriental strings.
4 cinematic-pop brasses.
4 clarinets.
4 accordions.
4 oriental organs.
4 saxophones.
Gala Free instruments:
3 pop strings.
4 clarinets.
4 saxophones.
Gala (both versions) has a full synthesis section, 2 different MIDI velocity options, a user friendly global hipass-lopass filter, a full section of built in effects (saturation, chorus, phaser, tremolo, reverb and delay), built-in draw-bars system per oscillator, an advanced mono mode, full MIDI map, stereo and gleam effect and a resizable and customizable GUI.
Prices:
Gala XL - is Royal pack member which costs $30.
Gala Free - is free.
»®Öصã:
Fanan team releases Gala - Multi Instrument EnsembleFanan TeamFanan team has released Gala, a multi instrument ensemble plugin.Gala replaces 7 instrument synths (Alkamanat, stringya, brassinematic, cl ...
