Massenburg EQ In VST And AU Formats
Massenburg DesignWorks MDWEQ6 high-resolution parametric EQ is now available
Massenburg DesignWorks says that, developed by George Massenburg, the new MDWEQ6 high-resolution parametric EQ continues to define the state-of-the-art in digital equalization and is now available for VST and AU applications. Two packages are available including AAX Native, VST and AU formats, with or without AAX DSP for Pro Tools HDX and Pro Tools | Carbon interfaces. A full demo version is also available.
This is what Massenburg DesignWorks has to say...
Following the successful introduction of the MDWEQ6 for Pro Tools in 2020, these new versions for both Mac (AAX, VST & AU) and Windows (AAX & VST) are a result of a large number of requests from customers for MDWEQ6 to support a wider range of applications, including Logic Pro, Final Cut X, Adobe Premiere, DaVinci Resolve, Digital Performer, Cubase, Nuendo, Pyramix, Ableton Live and Studio One.
Built on the venerable and unique MDW filter-form the MDWEQ6 includes a host of professional features including a new active spectrum display, new high and low pass filters, high Q shelves with sharper transitions, and node points for ease of parameter adjustment directly on the graph.
Refine sounds using constant shape reciprocal filter curves from the industry-standard reference - unlike other brands of plug-in products, the MDWEQ6 reliably processes audio exactly as it states making surgical 'EQ'ing' easier than ever. This new generation plug-in emulates the constant shape (i.e. reciprocal) filter curves of the industry-standard reference for parametric EQ, Massenburg's legendary GML 8200 equalizer. It performs as the user expects, not an estimation or compromise.
Pricing and Availability:
Version MDWEQ6-AAX+ full license is available from the MDW website for $329, including Pro Tools AAX DSP & Native, VST and AU plugin formats. MDWEQ6-Native+ for $199 includes AAX Native, VST and AU formats. Upgrades are available to both versions from $15 for customers with MDWEQ5 and MDWEQ6-AAX.
More information:
Massenburg MDWEQ6
More From: MASSENBURG DESIGNWORKS
More Stories:
Unearthed Chemical Brothers Interview From 1997
Mechanical Circle Guitar Interfacing With CV And Gate
Hands-On Online EQ Training
Chiral - A Holographic Synth For Ableton Live
KORG Ships Full Size MS-20
More Videos
»®Öصã:
Massenburg EQ In VST And AU FormatsMassenburg DesignWorks MDWEQ6 high-resolution parametric EQ is now available Massenburg DesignWorks says that, developed by George Massenburg, the new MDWEQ6 high-re ...
