Torso Electronics T-1, New 16-Track Polyphonic MIDI Sequencer With Ableton Link
SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
Torso Electronics T-1 is a new 16-track hardware polyphonic MIDI sequencer with random modulation features, menu free workflow and Ableton Link support
One of the highlights, in my opinion, is Ableton Link support that allow you to play in time with your DAW and all Link supporting applications. It¡¯s nice to see such a modern technology in a hardware sequencer. T-1 features 16 polyphonic tracks, 16 rhythmic and melodic parameters and unique live performance tools.
Especially the random modulation features make this sequencer very powerful. The developers added here turing inspired pseudo-random modulation to every parameter that creates endless musical variations. These can be locked into loops. Additionally, the musician can make relative parameter changes to multiple tracks simultaneously, what is an amazing tool for musical progressions.
No Menu, No Display
Torso Electronics has not installed a display in the T-1 sequencer here, but leave this work to the multi-colour keypads. These are used as a display showing the parameter values and the state of the unit. The unit also includes 18 endless encoders with them you can access all functionalities on the interface at all times. So, no menu diving.
On the connection side, it includes a USB 2.0 for MIDI & power, 3x MIDI on 3.5mm jack (input, output, thru) but no CV. The developers says about the T-1: we set out to design a machine that can go beyond the limitations of a traditional sequencer, while maintaining a simple and user-friendly interface with no menu diving. Focusing on fluid live performance and the possibility to modulate every parameter with random sequences.
Features
Euclidean rhythm generator
Per track note division
Note repeater
Melody generator
Timing and Dynamics grooves
Musical scales
Pseudo-random modulation
Temporary and global parameter changes
Autosave
16 patterns per bank
8 banks per project
16 projects
18 encoders & 23 RGB backlit silicone keypads
USB 2.0 (midi/power)
3 X MIDI 3.5mm jack (in, out, thru)
Ableton Link (WiFi)
Matte black aluminum casing
Dimensions: L:304, W:114, H:37mm
Weight: 850g
»®Öصã:
Torso Electronics T-1, New 16-Track Polyphonic MIDI Sequencer With Ableton LinkSYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, y ...
