阅读: 48888|回复: 1
[插件] Strezov Sampling MINImalism KONTAKT 钢琴和马林巴琴
发表于 2020-7-15 | |阅读模式
KONTAKT – 550 MB
受Steve Reich, Terry Riley和John Cage等人的启发,极简主义是一种电声虚拟乐器,为你的音乐添加有节奏的动作和乐趣。
“极简主义”是一个基于Kontakt的图书馆,它是在索菲亚会议工作室用多个麦克风录制的,后来被总结为三个麦克风位置。我们录下了两架钢琴和一架马林巴琴,它们的五度完美的合奏是为了实现库中独特的打击乐和圆润的声音。
库的用户界面被设计成仅用三个补丁就能给用户提供整个库的潜力。
你可以在每一件乐器的中间看到预置部分,在那里你可以浏览和选择这个库的预置。在右边你可以找到FX部分,包含不同的效果(压缩机,合唱团,弗兰格,失真,均衡器和卷积混响包含30个不同的脉冲响应),你可以使用它来制作自己的预置和创建自己独特的声音。
图书馆概况
-短距离(单音符)- 10xRR, A0 – F4(包括扩展射程)
– TREMOLO – 1xRR, A0 – F4
-测序器- 10xRR, A0 – F4
-动力学- 3层
Inspired by the likes of Steve Reich, Terry Riley and John Cage, MINImalism is an electroacoustic virtual instrument for adding rhythmic motion and interest to your music.
“MINImalism” is a Kontakt based library which was recorded in the Sofia Session Studio with multiple microphones, which were later summed into three microphone positions. We recorded two pianos and a marimba, all playing perfect fifths in unison in order to achieve that distinctive percussive and mellow sound of the library.
The user interface of the library is designed in a way that gives the user the whole library’s potential within just three patches.
In each of the instruments you will be able to see in the middle the Presets section, from where you are able to browse and select any of the premade presets for this library. On the right side you can locate the FX section, containing different effects (Compressor, Chorus, Flanger, Distortion, Equalizer and Convolution Reverb containing 30 different Impulse responses), which you are able to use to craft your own presets and create your own unique sounds.
LIBRARY OVERVIEW
– SHORTS (single note) – 10xRR, A0 – F4 (including the extended range)
– SEQUENCER – 10xRR, A0 – F4
– DYNAMICS – 3 layers
375
发表于 2020-7-27 |
谢谢楼主分享
