汽车混合
与rekordbox dj Automix,您可以轻松混合您的播放列表与信心和准确性。追踪短语由rekordbox的KORETECH引擎中一种全新的短语分析算法检测。此外,Automix使用音轨信息,如节拍位置、BPM和键,以产生自然的混合。你可以自由地划痕,应用FX和改变轨道的顺序,只要你想。
Purely pro performance. No waiting. rekordbox dj puts all of Pioneer’s superb DJ expertise into one package to produce the industry’s fastest, most stable software with sublime sound quality.
Professional sound quality
Purely professional. rekordbox dj employs sound processing from the top-flight CDJ-2000NXS player and DJM-900NXS mixer to provide superior sound quality.
Lowest latency in the business
No waiting. rekordbox dj has the industry’s fastest response time for natural, reliable control.
MULTI-DECK MIXING
Mix. Remix. Magic. Just like a professional remix station. Perform with 2 or 4 decks and use Pioneer DJ controllers for plug & play access to dope features, such as Hot Cues, Slicer and Slip Mode.
VISUAL BRILLIANCE. VIRTUAL HARMONY.
rekordbox dj’s GUI is perfectly matched with the layout of your hardware no matter what player or device you are using, including the new DDJ-RR and DDJ-RB. It’s simply the most effortless, intuitive software imaginable. The FX, waveform, players, sampler and browser mirror your hardware exactly, and you can choose from a 2/4-deck with horizontal or vertical views. Hot Cues, Sample and other effects offer intuitive operation to match the same layout as the pad control section in our DJ controller.
WHAT YOU SEE IS WHAT YOU GET
Find tracks quickly and easily using rekordbox’s enhanced browsing.
AUTO MIX
With rekordbox dj Automix, you can easily mix your playlist with confidence and accuracy. Track phrases are detected by an all-new phrase analysis algorithm in rekordbox’s KORETECH engine. In addition, Automix uses track information such as beat position, BPM and key, to produce natural mixes. You are free to scratch, apply FX and change the order of tracks whenever you want.
UPLOAD YOUR DJ MIX EASILY
Use rekordbox to record your sets and share them with the world via social media channels including Mixcloud, YouTube and KUVO. When you upload your mix, all track titles and time stamps are automatically added by rekordbox, so listeners can check each track title while enjoying your set.
MORE LIGHTS, MORE ACTION
It’s not a show without music and lights. New Lighting mode makes synchronizing your show’s lights super easy, while also offering you more space to get creative. The new software features an algorithm that automatically detects the variances of each phrase of a song to produce a perfectly synchronized lighting effects. That leaves you free to concentrate on your music. But if you want more control, Lighting mode gives it to your.
ONE MUSIC LIBRARY, UNLIMITED CONTROL
Take your entire rekordbox library and your DJ performance experience to almost any controller or CDJ. Or, use HID support to play from your laptop using a CDJ or XDJ set-up. rekordbox dj gives you access to more than music. Your entire set, complete with cues and tags, can be shared across platforms and devices while you unify managed music tracks with ease. Once you have rekordbox dj rolling, no doubt, the show will go on.
File size: 149 MB
DJ音乐管理软件 – Pioneer DJ rekordbox 5.8.5.0001 Premium MacOS
