阅读: 17228|回复: 2
[转载] FXpansion BFD3 Sabian Digital Vault WiN
发表于 2009-6-12 | |阅读模式
BFD Sabian Digital Vault是BFD3、BFD Eco和BFD2的Sabian档案馆的各种cymbals和hihats的集合。它的特点是各种精心取样的经典,原型和从Sabian档案中一次性的,适合所有风格的音乐。
BFD Sabian数字库包括HHX和AAX系列最受欢迎的系列,以及独特的堆叠式铙钹,神秘的叩击钹和4个超详细的hihat。在mallet和brush版本中也提供了一些选择的工具。录音是由抽样大师约翰·埃姆里奇(John Emrich)进行的,重点是鼓舞人心的新、令人兴奋的铙钹部分。BFD Sabian数字Vault在BFD3,BFD Eco和BFD2中使用工厂鼓的工具包预置。
亮点:
BFD3、BFD Eco和BFD2的扩展
总共41乐器
Rides, crashes, splashes, chinas, hihats
选择的mallet和brush版本
Kit预置与工厂鼓
原文
BFD Sabian Digital Vault is a diverse collection of cymbals and hihats from the Sabian archives for BFD3, BFD Eco and BFD2. It features a variety of meticulously sampled classics, prototypes and one-offs from the Sabian archives and is suitable for all styles of music.
BFD Sabian Digital Vault includes HHX and AAX series favourites alongside unique stacked cymbal setups, esoteric percussion cymbals and 4 hyper-detailed hihats. Selected instruments are also presented in mallet and brush versions. Recordings were conducted by sampling guru John Emrich with an emphasis on inspiring new and exciting cymbal parts. BFD Sabian Digital Vault comes complete with kit presets using factory drums in BFD3, BFD Eco and BFD2.
Highlights:
Expansion for BFD3, BFD Eco and BFD2
41 instruments in total
Percussion, effect and stacked cymbals
Selected mallet and brush versions
Kit presets with factory drums
FXpansion BFD3 Sabian Digital Vault WiN | 8.8 Gb
1206
 楼主| 发表于 2009-6-12 |
36
发表于 2020-6-13 |
谢谢楼主分享
