音频应用 首页 新闻资讯 查看内容
Spread Light By Yum Audio Is FREE For A Limited Time
2021-6-28 08:18| 发布者: canpos| 查看: 552| 评论: 0
摘要: Spread Light By Yum Audio Is FREE For A Limited TimeYum Audio offers its Spread Light (£39 value) stereo tool plugin as a FREE download for macOS and Windows.Spread Light is available for free downlo ...
Spread Light is available for free download in 64-bit AU, VST3, and AAX formats as part of a limited-time launch offer. Once the offer expires, the purchase price will be £39.
Spread Light comes with a very tidy little GUI, which is also resizable if need be.
If we start at the top, the first parameter we see is the Intensity that can be set from 0% to 100%. Intensity acts like a dry/wet control, adjusting the intensity or level of all other parameters in the plugin. The Intensity control can be automated, which is handy if you want to accent certain parts of a track more than others.
The main area of the GUI is where you deal with the Tilt and Width controls. These functions are similar to those you’d find in a plugin like S1 Stereo Imager from Waves.
Spread Light has two processing modes, M/S (Mid/Sides) and HAAS. You can change between modes using the mode selection switch.
M/S mode is standard mid-side processing, which is ideal if you just want to add some width to a specific element in your song. You can do this by adjusting the Width control, and the GUI gives you a nice visual representation.
In M/S mode, the Tilt function allows you to pan your audio hard left, right, or anywhere in between. If you Tilt hard left with a broad Width setting, you’ll still hear sound from both speakers.
HAAS mode is slightly different and utilizes delay to alter your perception of direction and space. The HAAS effect is a psychoacoustic phenomenon that occurs when there is a slight delay between stereo (left/right) channels making the sound arrive at slightly different times.
When in HAAS mode, the Tilt control adjusts the delay applied. If you Tilt to the left, the sound coming from the right will have a slight delay and will be perceived as coming from the left of the stereo field.
The last control to mention is the Gain slider found at the bottom of the GUI.
There are many stereo image plugins; I also like Stereoizer from Nugen Audio, which is worth checking out, although not great when on a budget.
Yum Audio is also offering the full (more in-depth) version of Spread at a launch offer price of £55.
It seems like Yum Audio could be one to watch for interesting plugins with a creative/musical approach. For now, I’ll gladly take this lovely little freebie.
Download: Spread Light (64-bit VST3/AU/AAX plugin formats for Windows & macOS)
路过
雷人
握手
鲜花
鸡蛋
相关阅读
最新评论
