音频应用 首页 新闻资讯 查看内容
Ginger Audio releases GroundControl - Free OS X Virtual Audio Driver
2021-4-11 13:52| 发布者: arbitron| 查看: 645| 评论: 0
摘要: Ginger Audio releases GroundControl - Free OS X Virtual Audio DriverGinger Audio has announced the release of GroundControl, a Virtual Audio Driver for OS X with control room monitoring options.Ground ...
GroundControl virtual audio drivers allow applications to pass audio to other applications with zero latency. It also allows you to pass your system sound to other applications on your Mac.
GroundControl allows you to monitor the driver's stream through your computer's internal speakers, headphones, or any audio interface you have.
It features:
A volume control knob.
In & Out meters.
Peak meter.
Dim/Mute/Mono.
GroundControl works on all OS X versions (up to the latest Big Sur) and runs also the latest Apple Arm architecture. It has 3 virtual audio drivers (2, 16 and 64 channels) + a control room application.
Download for free at gingeraudio.com/downloadgroundcontrol
路过
雷人
握手
鲜花
鸡蛋
相关阅读
最新评论
原创周排行
